Wells Fargo
Last activity: 25 Apr 2018 7:04 EDT
Using Weblogic plugin instead of reverse proxy in apache to reach application in weblogic
How to set up single sign on with Apache/Siteminder/Weblogic and Pega?
We are using Weblogic plugin connector to connect with Apache and not using reverse proxying.
Issue we have now is, once the user is authenticated and authorized in Siteminder, instead of taking the user to application portal page, it displays the pega login page. As user profile is set up to authenticate externally, even if login creds are re-entered in pega login page, it fails.
***Moderator Edit: Vidyaranjan | Updated SR details***
