Advantages on Auto discovery in SMA on Pega Cloud
What are the advantages on Auto discovery in SMA on Pega Cloud?
On Pegacloud SMA runs on each node along with prweb
Rather than relying on Nodes.xml files, SMA will talk to prweb which will then use cluster information from pr_sys_statusnodes to discover all the running nodes and build the list for prsysmgmt.
This only works Pega Cloud and every node have the same jmx port and no jmx authentication.
