Northbridge Financial Corporation
Last activity: 26 Jul 2020 22:16 EDT
Pega Application- Health Check
do we currently have a way to quickly determine whether PEGA is online or offline? is there an API/URL that we can hit to get this status?
Updated: 11 May 2020 15:51 EDT
You can verify whether a Pega 7 Platform instance is up and running by entering this URL: http://<<hostName:port/contextName>>/PRRestService/monitor/pingservice/ping
https://docs-previous.pega.com/performance/pinging-pega-7-platform-instance
Thank You
Lars Ackermann Rafique Mohammed
Just FYI:
The monitor/pingService/ping Rule-Service-REST wasn't added to the Pega Platform until version 7.1.9.
For 7.1.8 there is Hfix-29529 that is a backport.
The HFIX is actually HFIX-29592*
Centene
When JVM is busy and running GC, the response from the application node is getting delayed which is causing LB to reroute the requests to other nodes. How does that scenerio can be avoided ?
Centene
And I noticed, this service is not available in 8.3.x versions. With fresh installs, this service is not available anymore. What is eplaced for this service?
Centene
And I noticed, this service is not available in 8.3.x versions. With fresh installs, this service is not available anymore. What other service is replaced for this service?
Centene
BNYMellon Technology
How do we check SMA health check after deploying prsysmgmt.war ?
Cognizant
Is the same ping service also available in Pega Infinity (Platform version 8) ?
{context}/PRRestService/monitor/pingService/ping
Pratik Agarwal
Cognizant
Answer: Yes. I just checked :)
Wipro
Hi @pratik ,
We are using pega 8.2.6 and could not find pingservice in "monitor" service package.
I am not sure where exactly you found this service. Could you please let us know in which service package you found this service.
Thanks !!!
Any help from others would highly appreciated !!!!
