How To Sort amount property in Case ID
hai
I have a scenario, I want to pull the assignments the case with the higher amount (assume we have 5 WO with amount property )should be pulled out first
hai
Hi ,
Please refer the below link which might help:
Vikash
my scenario is not there at the above link. when we pull work objects according to the amount property whichever is the higher amount(50000) it shows first and then next higher amount (45000) it has to show like that..
Hi @DODDAN53,
Thanks for posting on PSC.
1. SaveAs "GetNextWork" activity in your application rule-set.
2. SaveAs "getContentForGetNextWork" with the different name and add your business logic as Java code.
3. Refer the new activity created(in step2) in GetNextWork listview.
- Similar use-case It will give you the idea.
Hope above post helps you in implementing your business requirement. Kindly notify if it does by marking this post as answered.
Asif
hai @Asif-Hasan
thanks for your help but i don't no java code , so please tell me is there any other way we can achieve this scenario.
