DXC Technology
BE
Last activity: 6 Mar 2018 9:39 EST
Warnings during server start up
I am getting the following warnings during server start up. It doesnt seem to affect the functionality though. Could you please help in understanding it and help in steps to remove this warning during server start up.
[3/6/18 12:25:01:484 CET] 00000016 SystemOut O 2018-03-06 12:25:01,484 [ was10000.bc] [ STANDARD] [ ] (res.CacheDataToCandidateMapper) WARN - Unable to load RULE-OBJ-MODEL WBC-DATA-RESOURCESETTINGS LOADCOMMONWBCRESOURCESETTINGS #20160726T150505.931 GMT due to Database-BadClassDef WBC-Data-ResourceSettings; This may cause the wrong rule to run during rule execution.
[3/6/18 12:25:01:546 CET] 00000016 SystemOut O 2018-03-06 12:25:01,546 [ was10000.bc] [ STANDARD] [ ] (res.CacheDataToCandidateMapper) WARN - Unable to load RULE-OBJ-MODEL WBC-DATA-RESOURCESETTINGS LOADFAULTSETTINGS #20150629T155330.808 GMT due to Database-BadClassDef WBC-Data-ResourceSettings; This may cause the wrong rule to run during rule execution.
[3/6/18 12:25:01:546 CET] 00000016 SystemOut O 2018-03-06 12:25:01,546 [ was 10000.bc] [ STANDARD] [ ] (res.CacheDataToCandidateMapper) WARN - Unable to load RULE-OBJ-MODEL WBC-DATA-RESOURCESETTINGS LOADFAULTSETTINGS #20150917T101115.246 GMT due to Database-BadClassDef WBC-Data-ResourceSettings; This may cause the wrong rule to run during rule execution.
[3/6/18 12:25:01:546 CET] 00000016 SystemOut O 2018-03-06 12:25:01,546 [ was10000.bc] [ STANDARD] [ ] (res.CacheDataToCandidateMapper) WARN - Unable to load RULE-OBJ-MODEL WBC-DATA-RESOURCESETTINGS LOADFAULTSETTINGS #20151231T115738.782 GMT due to Database-BadClassDef WBC-Data-ResourceSettings; This may cause the wrong rule to run during rule execution.
[3/6/18 12:25:01:546 CET] 00000016 SystemOut O 2018-03-06 12:25:01,546 [ was10000.bc] [ STANDARD] [ ] (res.CacheDataToCandidateMapper) WARN - Unable to load RULE-OBJ-MODEL WBC-DATA-RESOURCESETTINGS LOADFAULTSETTINGS #20160107T110432.503 GMT due to Database-BadClassDef WBC-Data-ResourceSettings; This may cause the wrong rule to run during rule execution.
[3/6/18 12:25:01:546 CET] 00000016 SystemOut O 2018-03-06 12:25:01,546 [ was10000.bc] [ STANDARD] [ ] (res.CacheDataToCandidateMapper) WARN - Unable to load RULE-OBJ-MODEL WBC-DATA-RESOURCESETTINGS LOADFAULTSETTINGS #20160116T182146.152 GMT due to Database-BadClassDef WBC-Data-ResourceSettings; This may cause the wrong rule to run during rule execution.
[3/6/18 12:25:01:546 CET] 00000016 SystemOut O 2018-03-06 12:25:01,546 [ was10000.bc] [ STANDARD] [ ] (res.CacheDataToCandidateMapper) WARN - Unable to load RULE-OBJ-MODEL WBC-DATA-RESOURCESETTINGS LOADFAULTSETTINGS #20160119T115322.599 GMT due to Database-BadClassDef WBC-Data-ResourceSettings; This may cause the wrong rule to run during rule execution.
[3/6/18 12:25:01:546 CET] 00000016 SystemOut O 2018-03-06 12:25:01,546 [ was10000.bc] [ STANDARD] [ ] (res.CacheDataToCandidateMapper) WARN - Unable to load RULE-OBJ-MODEL WBC-DATA-RESOURCESETTINGS LOADFAULTSETTINGS #20160701T130319.429 GMT due to Database-BadClassDef WBC-Data-ResourceSettings; This may cause the wrong rule to run during rule execution.
[3/6/18 12:25:01:546 CET] 00000016 SystemOut O 2018-03-06 12:25:01,546 [ was10000.bc] [ STANDARD] [ ] (res.CacheDataToCandidateMapper) WARN - Unable to load RULE-OBJ-MODEL WBC-DATA-RESOURCESETTINGS LOADFAULTSETTINGS #20160715T054646.548 GMT due to Database-BadClassDef WBC-Data-ResourceSettings; This may cause the wrong rule to run during rule execution.
