Setting character limit to autocomplete fields
Hi! Is it possible to set maximum character limit to autocomplete field?
One way to achieve this is you can fire a validation on submit of the flow action to validate the value and checking for desired maximum characters. Or use an edit validate in the property used for the autocomplete filed in that you can define the maximun length for that property.
