Property with max length of 24 throws an error stating String too long
Got a property set in an activty. The said property has a max length of 24 defined in its advanced tab. After property set, there's a error on the page stating the value for this said property is too long, it should be only 23 characters while the value we have is of 24 characters which exactly complies with the max length constraint. The property is of text type and we don't have any validations running for the same. There's a "Default" control for this property. So, not sure what is causing this error since the value is within the defined constraint of max length.
Any inputs on the same would be helpful.
