I want to read the outlook email with specific subject and needs to save attachment file in email to local drive. How do I this automation?
Tried using the method mentioned in the link bujt not able to resolve it
http://help.openspan.com/80/Components/Microsoft_Outlook2.htm
Refer attached screenshot.
Steps: 1. Drag Findmail method, provide folder and subject details (It will return single mail match only, if you want to retrieve all mails in a folder then use RetrieveMail and build login accordingly)
2. Extract proxy for mail
3. Drag attachments property from above proxy
4. Extract proxy for attachments
5. Drag GetItem from above proxy (Screenshot contains logic for first attachment if you have more than 1 attachments use loop)
6. Extract proxy from Result of GetItem method
7. Drag SaveAsFile method from above proxy (provide path to save the attachment)
