Citigroup Inc
Last activity: 7 May 2018 12:27 EDT
Certificate invalid path error
Problem Summary –
- As part of CICD implementation using prpcserviceutils command line tool, we are not able to establish operator connectivity using secure http.
For e.g. – we have used serviceConnection.properties file with contents like below –
- cat serviceConnection.properties
DefaultSystem1.pega.rest.server.url=https://hostname:port/prweb/PRRestService Must to use secure http URl for UAT and PROD env
- The error which we receive while performing product export –
- Using command - sh prpcServiceUtils.sh export --connPropFile serviceConnection.properties
- With above command the build fais with error as –
[java] java.security.cert.CertPathValidatorException: The certificate issued by CN=Citi Root CA G2 UAT, O=Citigroup Inc., C=US is not trusted; internal cause is: [java] java.security.cert.CertPathValidatorException: Certificate chaining error
[java] Error Messages : REQUEST_EXECUTION_ERROR com.pega.pegarules.serviceclient.exception.PRPCServiceException: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
Steps to reproduce the error –
Problem Summary –
- Very much possible – the CICD setup is available on DEV servers and problem can be reproduced when required
Troubleshooting steps performed so far –
- Ordered JKS certificate and imported on server successfully. No issues here
- Added following JVMs at WebSphere application server to establish imported JKS connectivity with Pega application and UI (https URL)
- -Djavax.net.ssl.trustStoreType=jks -Djavax.net.ssl.keyStore=/CPR/app2app/cert/keystore.jks -Djavax.net.ssl.keyStorePassword=xxxxx -Djavax.net.ssl.trustStore=/CPR/app2app/cert/truststore.jks -Djavax.net.ssl.trustStorePassword=xxxxx
- After updating above JVMs we have restarted the application instance on websphere server. During node startup we get following error –
Present status -
- CICD pipeline works well with http however it is failing for certificate errors for HTTPS operator connectivity as highlighted above.
Also, the Pega SR – C10592 has been updated with details and awaiting a response.
