Skin Changes not applying to portal
Hi have a skin applied to a composite portal. The portal launches my application flow which contains a Tree Navigation Harness. I have a few dynamic layouts and grid repeat layouts. When I apply any border/background changes to the skin, I am not seeing them applied to the layouts. However if I include a custom CSS in the skin, the changes are visible on the harness immediately.
In the developer portal I have created a dynamic layout and embedded a grid layout. The grid layout has default style and no container format. In the style sheet I have set the grid background as white for the rows. But when I launch the flow I still see the row (highlighted in blue) with a gray background. Also I have a dynamic triple inline grid with a border and it does not show a gray background although the skin preview shows it.
I am not sure if it is a setting in my developer portal or if I should be using Custom CSS in the included styles tab of the skin.
Sameer
