HCL
MY
Last activity: 24 May 2018 6:49 EDT
Local Action is not launching on click of button
In Pega7.3,Local action is not launching on click of button.It is not showing any error message also,One more thing Same code is working in pega 7.1.Please help.
Thanks @NEPALK81 for sending us the resolution:
Initially the value of Enable client-side template UI was set to Pega Default in harness rule of Advanced Tab,
To fix the issue I have change value of Enable client-side template UI to No and issue got fixed.
Hi ,
I have configured local action on click of a button in 7.3 as below at it is working fine for me:
I have configured the local action with Modal dialog box.
Please attach the screen-shot of your configuration.
Vikash
HCL
MY
Hi Vikash,
I have not configured anything new in pega 7.3,We have just upgraded from 7.1 to 7.3 .In 7.1 it is working fine but in 7.3 it is not working, Please find the screenshot below. Please advice whether we need to apply any hotfix or we need to create the section in work class.
Is Local Action "DeleteAlert" exists in your application?If yes, please check the section it refers. Maybe revalidating and saving these rules might solve the issue.
HCL
MY
Yes Rachit Everything exists. Please refer the screenshot. Please suggest.
Please check the Network Trace along with the suggestions provided by Sibani.
On click of Button, did you try to trace? Is it tracing? Do you see any error?
Are there any error in the logs and UI?
Could you please attach tracer and logs to investigate further.
Regards
Sibani Saidarsini
HCL
MY
Hi Sibani,
I tried to traced but I am not getting any error message on log or at UI or at tracer .Please check the screenshot of tracer as well as screenshot of UI after click on button. On click of delete button ,system is displaying one Dark screen. Please refer the attachment.
In your shared tracer document i can see a FAIL message on 138 line, could you cross check it.
HCL
MY
Hi Mahesh,
That Fail message also happening in pega 7.1 tracer but in 7.1 local action is launching .But in 7.3 it is not working. The exact issue is not with this fail message.
The Tracer doc attached shows a fail at step 23 of ProcessAction. What was the error in Tracer for that step?
HCL
MY
Viji Rao
Do you see any errors in console(Developer Tools), when you click on the button.
Swiftrinity
LK
This answer is fixed my issue. thank you
Legato Health Technologies LLP
Hi Lochana,
As you suggested i updated the harness rule to set the "Enable client-side template UI" to No. Still popup window is not opened. we are opening the popup window on click on button. on click on button we are using a local action and target as Modal Dialog.
The above solution was recorded as successful by @NEPALK81. Please create a new post to start a new discussion and receive correct guidance on your use case.
Thanks!
