![](https://accounts.pega.com/sites/default/files/pega-user-image/436/REG-436290.png?source=PUMINIT)
UBS
Last activity: 19 Jul 2018 11:17 EDT
Getting " VisioSaveFailed" while saving a case in Pega 7.2
Hello
I am getting "VisioSaveFailed" while saving a case into temporary case.
- On the Process tab, locate the Case Creation setting section and select the Temporary object check box.
Radha Deshmukh Ravinder Arra Sabarish M -
Is this part of an upgrade from a prior version where the flow was edited from visio? Also please mention that version if so.
UBS
I am using 7.2 and not doing any upgradation activity. This error occurs when saving an existing case into a temporary case.
Sakhatech Information Systems PVT Ltd
Im experiencing the same issue , what could be the reason ? (all ruleset are saved )
Atos
I have the same problem when doing the exercise on creating temporary cases in the cssa course.
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/2024-07/151480df-12c4-4f58-aa60-3ac83bb90767.jpg?h=c549b6fa&itok=dPLCOQd-)
Can you be more specific? When creating a temporary case you are simply selecting Temporary Object on the Process tab of the pyStartCase flow. What is giving you an issue? Please include a screenshot.
Sean
Pega Academy Self-Study Support Team
Atos
I found the cause of the problem. I made my change on the wrong (01-01-01) ruleset. When I saved the rule to the new ruleset version I could save the ruleset without errormessage.
Tyler Smith kesavram Ravichandran
Glad to hear it is resolved.
Sean
