HAP
Last activity: 22 Feb 2018 4:03 EST
Column Populator utility alternative
For some reasons, column populator utility is not successful in our environment. We are working on it through a Pega SR. But my question here is on an alternative approach.
If we expose a new column, say ColumnA, in our work table, can we use a simple update query like below to populate the column values?
Update <WorkTable> Set ColumnA = pr_read_from_stream('.ColumnA', pzInsKey, pzPVStream)
We can also control the magnitude using 'where' clause on create date column. Does column populator utility does something extra which we may lose by following query approach?
