Performance improving Tomcat params
I've recently installed an instance of PRPC 7.3.1 on a intranet VM, using SQL Server and Tomcat 8.5.
This is my first Tomcat install from scratch, and as the system can be very slow at time with only me logged on, I feel like there are things I'm doing wrong/ways to improve this in the Tomcat conf files (setenv.bat, setDomainEnv.bat, server.xml, web.xml).
In setenv.bat, I edited the catalina and java options based on online advice to be:
set CATALINA_OPTS=%CATALINA_OPTS% -Xms4096m -Xmx8192m
set JAVA_OPTS=%JAVA_OPTS% -server
In server.xml, I edited the Connector based on online advice to be:
<Connector port="80" protocol="org.apache.coyote.http11.Http11Nio2Protocol"
connectionTimeout="20000"
redirectPort="443"
maxThreads="400"
minSpareThreads="40"
maxKeepAliveRequests="1000"
compression="on"
compressableMimeType="text/html,text/xml,text/plain"/>
In web.xml, I edited a few servlet params based on online advice to be:
development = false
trimSpaces = true
For reference, the VM running Tomcat is separate from the VM running the database server. The Tomcat VM is a 64bit Windows system with a single 2.6GHz processor and 12GB of RAM.
redirectPort="443"
maxThreads="400"
compression="on"
development = false
trimSpaces = true
Any better ways to do this? I've of course referenced the installation guide on the PDN, which doesn't go into much detail on this infrastructure side of things.
