EAI Systems
SA
Last activity: 30 Jan 2018 6:21 EST
Send Report through mail in the form of pdf
How to send report(created in report defnition) through mail in the form of attachment(.pdf)
Shweta V Singh.
Hi Shweta,
You can able to use the Schedule report option to send the report in a mail in PDF format in report browser.
Hope this is what you are looking for.
Regards
Mahesh
Recently i had gone through this Pegatube video about the Schedule report configuration and troubleshooting tips, you can have a look into it for easy understanding.
EAI Systems
SA
I did that but the mail is not sending i am not gettting what is the error exactly. Is there any solution for this?
The above shared video has some troubleshooting tips for scheduled reports failure, may be you can try those suggestions and cross check in the logs for any errors related to the send mail failure error messages, if any.
You can also have a look at below discussion
https://collaborate.pega.com/question/can-we-directly-attach-pdf-and-send-it-email
Arun
Priyanka Ghongade
Verizon Data Services
There are other ways of accomplishing this as well.
1) Generate the pdf and attach it with the case and hence u will have the link-attachment key . You can call the OOTB activity SendEmailWithAttachment to send email with the pdf.
2) Download the pdf in the export directory and then attach it to ur mail and finally delete from the export directory.
