Sensiple Software Solutions Pvt Ltd
Posted: Jan 5, 2018
Last activity: Jan 5, 2018
Last activity: 5 Jan 2018 8:29 EST
Can someone help me in reports,
I need to add all the data of a single value property and display as a summary( single row) below my report. how can i achieve this?
Regards
Hi Suganya,
I had implemented a sample use case to test your requirement in Pega 7.2.2 and attached for your reference. Could you look into it and let me know if that satisfies your requirement.
Regards
Mahesh
Hi Mahesh,
I couldn't find sum option in the summarize column.
Regards
Suganya
Sum option will be shown only for properties/columns of numeric (integer/decimal etc).
Change your single value property to be of type integer to get SUM option.
