How can we wrap the column header label and the column data in a report definition? The column label and data are not seen in full when its longer
We have exactly the same question... Will have to hard code the column width or use custom sections to view report if we do not find the solution.
we hard coded the column width..
In my Report Definition, i want all the text,dates etc to be center alligned.
Can anyone help me how to acheive this?
Venkat
Venkat
This can be accomplished by going to the Application Skin and choosing the Trees & Grids component. From there you can modify and exisiting style or clone one. To center align the text select the Rows tab and add the Text-Align Center under Additional Styles for both Odd and Even Rows..
Sean
Pega Academy
Goto row options(query Tab) in report definition.
Hard code the columns width and use number or disply in Column Format as center.
