Calendar Gadget Missing from Case Manager Portal PRPC 7.3.1
Hi Team,
I am unable to view the calendar Gadget in PEGA 731 Case Manager Portal when I am creating a new Applciation, however If I login with Administrator@pega.com and run the case manager Portal I am able to see the following in the Menu.
I am currently using the ootb CaseManager Portal and harness in the new Application. Also I could see that the Section: pxCalendarViewGadget is set as final and deprecated.
Please let us know what is the alternative solution to have the following available in the case manager portal as we have multiple requirements from our customer to have a calendar gadget to view the cases assigned and see the SLA and other features which was available in the old version.
Gaurav
