Contra Costa County
Last activity: 23 Aug 2018 19:06 EDT
Pega Robotic Automation Runtime
Is there a way to automate the installation for Robotic Automation Runtime by clicking the OpenSpanRuntimeEntSetup.exe once and will finish the installation by itself?
Likes (1)
faith rolfsen -
APP_TOGGLE=AGILEDESKTOP
You can experiment and find all the switches/parameters that you want by outputting a manual install with logs and then find the switches/parameters to all the items you want to use (that's how I found out about this one).
You can silent install Pega Robotics through command line. Is this what you mean by "automated install"?
http://help.openspan.com/71/Citrix/Installation_From_the_Command_Line.htm
Contra Costa County
Thanks, Mitchell, this is what I'm looking for.
Contra Costa County
Hi Mitchell,
How to configure to run then "OpenSpan.AgileDesktop.exe" instead of "OpenSpan.Runtime.exe" during the silent install installation? I don't see switch or parameter for this on the document.
Thank you.
Contra Costa County
Thanks, Mitchell.
Here is the link to the current installation instructions. Check out the section on installing from the command line which contains all of the available options.
