Anthem
Last activity: 5 Dec 2017 8:18 EST
Upgrade from 718 to 731,Database-NonexistentTable error followed by upgrade failure.
Hi Team,
While trying to upgrade from 718 to 731,we are observing the below mentioned error and the upgrade is getting failed.
We dont have a table by name PEGA_RULES.pr4_rule_service_rest in any of our environments but not sure why the upgrade script has been trying to upgrade a non-existent table and getting failed.
[java] Nov 29, 2017 11:08:57 AM com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega
[java] SEVERE: Problem during method invocation (main)
[java] com.pega.pegarules.pub.database.NonexistentTableException: Database-NonexistentTable PEGA_RULES.pr4_rule_service_rest PegaRULES
[java] From: (unknown)
***Edited by Moderator Marissa to add SR Details***
The bypass.pega.schema property has been set to true but the schema changes needed for the upgrade have not been generated and manually applied.
To have the upgrade generate and apply the schema changes needed remove the =true from the bypass.pega.schema property in the setupDatabase.properties file and then resume the upgrade.
# Generate schema will be skipped if this property is set to true
# Note: Leave this property blank if you need to generate the schema
bypass.pega.schema
