Verizon
Verizon
Verizon
Posted: Nov 20, 2017
Last activity: Nov 21, 2017
Last activity: 21 Nov 2017 5:58 EST
How can I add a Report Definition in a section, instead of loading it in Report Viewer.
Hi Naveen,
If your intention is to display the content of the report definition in the section rule, then you can add the repeating layout grid and source it with the report definition to display the report definition data into your section or use Table to source the Report Definition if you are using 7.3+. If this is not your requirement can you please elaborate it.
Regards
Mahesh
HI Naveen,
Please take a look into OOTB section @baseclass pxUIGalleryBasicGrid. See attached.
It uses Report Definition to retrieve / display the data for the grid table in the section.
Susan
