Ernst & Young LLP
Last activity: 10 Apr 2019 15:06 EDT
Not able to sent email from Openspan Microsoftoutlook connector
Hi
I am facing issue in sending email using microsoftOutlook connector. Please find attached image of automation.
I can debug this automation step by step but when send method executes i don't see anything further step happening , there is no response. Even nothing is getting logged in Runtime log.   If I use display method in Automation I can email message with all provided details like email id, subject and body.
Please help.
Hi Prashant,
It worked for me the same way you configured.
The only change I tried is there is no data link between New Email Method and ProxyOutlookMail Component. or I have used directly New method of MicrosoftOutlookMail Component as shown in attached screenshot.
Param
It looks like your log says the email address in the To property is not in a valid format. Try entering the address again to double check the format is proper.
Ernst & Young LLP
Thank you for your reply. I noticed this error before in log and confirmed on email id but its correct.
Also please find attached image, It throws this error if I use "microsoftoutlookmail"  connector directly instead of using using proxy from "microsoftOutlook" connector.
Thanks .
I don't see an error in that attached image. Maybe you attached the wrong image?
Ernst & Young LLP
Updated image. Please check again.
Ernst & Young LLP
Can anyone please help on this? Thanks.
Hi Prashant,
Param
Emtec Inc
This Automation Sending mail with attachment didn't work for me. It Sends the email without attachment even if addAttachment method in automation.
Please help with this.
