Virtusa UK Ltd
Last activity: 25 Oct 2017 9:53 EDT
Why do we need to revalidate rules?
Hi
We have done ruleset skimming for few of the rulesets and deployed to QA. There were few parse XML rules and XML sreams rules were not getting invoked during a soap call. Once we revalidate those rules, it started working. Then we have deployed the same build to PROD but now different set of rules were failing and we had to revalidate them. Basically I need to understand why do we need to do this revalidation? why cant pega handle this smoothly? Should we do any post deployment steps like running static assembler etc. Its not consistent across environments as I had to revalidate different rules in different environment which proves the problem is not in the build but the deployment or environment issue. Can some one throw more light on this? As we see this more after the skimming, it was happening even before as well. So skimming cannot be a root cause.
Ganesh
