Display drill down data in the same report
Is there any way to display drill down data in the same report instead of opening a new section?
Thank you!
Thank you!
I assume you are referring to the behavior in the report viewer where the summary report is replaced in the window by the drill down report. If you want to keep the summary report visible and display the drill down elsewhere in the same window (e.g., below the summary report), I don't believe there is any provision to do so in the current implementation of the report viewer.
Hello Vidyaranjan,
Did you get any solution for your problem. I'm having a same requirement to do.
Vikas
Thank you for posting your query in the PSC. This looks like an inactive post and hence, we suggest you create a new post for your query. Click on the Write Post button here. Once created, please reply back here with the URL of the new post.
