QBE
Robotics Excel Connector - File Open - Use file name from string variable
All,
I am working on a PoC, that should open a Excel File from a directory and read a column value from current active sheet. Use that value to do some calculation and set the calculated value on to another cell.
Using Excel connector, in the "Open" method, if I directly set the filename on to the "workbook" property, I am able to open the Excel workbook.
However, I wonder, is there a way to set the Open->"workbook" property value from a variable, instead of hard coding the file name on the property.
The robotics studio doesn't allow me to link a string variable value as an input to the "Open" method..
Appreciate your inputs / suggestions to work this around.
Many Thanks in advance!
I am using :
1.)
Pega Robotics Studio
Version 14.0.23107.0 D14REL
Microsoft .NET Framework
Version 4.6.01586
Installed Version: Express
Pega Robotics Studio 8.0.1039.0
2.)
Microsoft office 2016.
All,
I am using :
1.)
Version 4.6.01586
2.)
