Aarete
Last activity: 21 Jul 2021 8:59 EDT
Pega Robotics: Unable to assign string value to global variable
Environment - Using Pega Robotics 19.1.81 plugin with VS2015
I am unable to assign value to a Global variable.
Following are the steps I did:
1) Created a globalDictionary object in _GC_Activities in Adapter Project
2) Added a global variable <Value Name = "Log" Type= "String"/> in the interaction.xml
3) In the adapter project setting the value of GlobalDictionary Log object. Out from the stringUtils.Concat is assigned to Log. I even tried setting value from a string variable
4) Created a globalDictionary object in _GC_Controller Project. This points to the same interaction.xml as the adapter Project
5) Added an automation in Controller Project under Events folder. GlobalDictionary -OnLogChanged.and doing some code
Things not happening:
1) In the adapter project the value output from StringUtils is not getting set to globalDictionary Log variable (global variable)
