Acxiom LLC
Last activity: 11 Oct 2017 19:14 EDT
Is it possible to group case instances based on a single property value in pega 7.2.2?
I have an application where I need to process invoice payments and I can have multiple invoices for the same payee and want to issue just one check for all the invoices together. In this application, each invoice is a case instance and I want to know is there a way by which I can group the case instances (multiple invoices) together in a new case instance and process them all at once.
Thank you in advance!
