OpenSpan Error While Executing Solution
Hi, community. Hope you were fine.
I am trying to run a solution and when I tried it, appears this error:
Also, I can add that I was modifying an automation and then appears "Entry Point Not Found", so I deleted it and added it again. In fact, that fixed the error but induced to this new error.
The solution appears to run normally but it is not ok to get this error.
Thanks in advance
