Anamata
Enable security policies by default
Is it possible to enable the security policies by default during or right after installation?
(without having it to manually enable it from the settings panel after logging in for the first time).
(pega 7.2.2 and/or pega 7.3 platform)
JP Morgan
Are you referring to rule level security policy or container level?
Anamata
The one set at "System > Settings > Security Policies > Enable Security Policies". I assume you call that container level.
JP Morgan
This setting is pretty much for a user with SysAdmin previlage to enable "captcha" on operators.
I don't see an option from server to enable captcha (tried with tomcat). The only way possible would be manually performing this change once in "Security Policies" once your instance is up.
Note: In cluster environments every tenant can have their own policy and if the user is shared the change will need 10 mins to reflect across instances.
Anamata
I'm trying to automate as many configuration settings as possible. However, for now this (relative simple) setting still remains a challenge. ;-)
Anamata
Anyone?
Manually configured security policies are stored as data instance in database. may be you could update/import this record as part of the install or deployment(?).
Anamata
That's a good suggestion. Will try and figure out where this value is stored in the DB. Thanks!
looks like its stored under table 'pr_data_admin'.
select * From data.pr_data_admin where pxobjclass like 'Data-Admin-System-AuthPolicies';
RCDTS
I'm new to this, so don't take this as gospel, but...
If you update the rule from the Designer Studio it saves rule Data-Admin-System-AuthPolicies.AuthenticationPolicies. You can see that rule under that class in the 'App' browser. It's got a system name associate (pega) and a production level.
You might want to exercise caution migrating this data instance, in case you lock yourself out.
