How to invoke/call a section rule inside a Java Script
How to Call or Invoke Section rule(Rule-HTML-Section) inside a java script
Thanks in Advacne
Thanks in Advacne
You can invoke the section using JSP tag below
<%pega:include name="Test" type="Rule-HTML-Section"%>
If your requirement is feasible to call the section using JSP tag use <pega:include name="Test" type="Rule-HTML-Section"/>
But if you want to call it from only Javascript then i couldn't find any option.
