  GE
Last activity: 14 Sep 2017 5:51 EDT
Checking PRPC Index files in detail
I am trying to user LUKE tool to check the Index of PRPC. How to proceed with setting up index. I don't see .idx files in the index folder.
Luke is throwing error "No valid directory at the location". The whole directory cannot be copied as it is more than 15 GB.
What are the main files I need to put in my local to make my Luke read it ?
Hello Bargavi,
If you have any issues in following the steps specified in above link to make the Luke tool compatible for elastic search indexes, you can look into this link where you can download the file which is already prepared to open the elastic search indexes in luke.
Hope it will help you to successfully download and try to open the search index files.
Regards
Mahesh
Hi Bhargavi,
May i know which version of PRPC you are trying to configure the Luke, inorder to know whether the search is Elastic/Lucene.
Mahesh
  GE
I am using 7.1.8.. Not sure what is the elastic verison.
  GE
Which version of luke should I take for this ?
Hi Bargavi,
Elasticsearch (elastic.co) is an open source, distributed, real-time search and analytics engine, designed for use in distributed environments where reliability and scalability are essential. Elasticsearch is used in the Pega Platform 7.1.7+ as the underlying engine for its full-text search feature.
By default the Luke tool doesn't support the Elastic Search indexes reading, so i tried to search the usage of Luke with the Elastic Search index files and found this link.
Kindly go through it for more information about the usage of elastic search index files using luke tool.
Regards
Mahesh
You can look into this page for information about the Elastic Search in Pega from 7.1.7 onwards.
  GE
Thanks these links were helpful. But which version of luke should I use ? Since the error says toooldformatexception and let me know what is the dependency jar that needs to be added ? I am using PEGA 7.1.8 index files
Hello Bargavi,
Regards
Mahesh
Hello Bhargavi,
For more information on Luke please go through below url
Arun
