Is there any way to highlight production level env.
We usually switch between Dev/QA/Prod a lot, and must be very careful when release product from Dev to QA.
Sometime, product which needs to be released to QA was releases to Prod. by mistake.
So, is there any way that Dev/QA/Prod can be differed easily? Either change the logo or color of fonts is fine.
Thanks for any suggestion.
Why not have additional layer of security while logging into prod environment. Or different login screen for prod environment can also work.
If you looking to change something on appearance basis you can look into this(https://collaborate.pega.com/question/pega-7-custom-background-color)
Thank You.
