How to Remove Duplicate in PageList
We have page list ElementList.pxResults and have property CLM_Numbers.
I just want to remove the duplicate values for CLM_Numbers in ElementList.pxResults page list. Could see OOTB functions but not able to use it.
Please help me on this.
Hi Raj,
I had tried to remove the duplicates from Page List with a sample use case as explained in attachment.
Hope it might help you to achieve your requirement.
Regards
Mahesh
https://collaborate.pega.com/discussion/remove-duplicate-values-pagelist-using-same-pagelist
Please look into the above link, that might be helpful for you.
You can refer DecisionParametersUtils.RemoveDuplicatesInPageList function to remove the duplicate values in pagelist
J.P. Morgan Services India PVT Ltd
please refer to the link and go through the document attached.
Thank you
Vodafone Shared Services India
Can you try this:
ClipboardPage ListPage1 = tools.findPage("ElementList");
pega_rules_utilities.pyRemoveDuplicatesFromPagelist(ListPage1,".pxResults","CLM_Numbers");
Vivek Reddy Purra
Hi Raj,
Regards
Mahesh
Anupriyadarshinii Rajasekaran Rohith Achanta Prudhvi Raj Kavitha Kuppusamy Vishnu Vardhan and 7 More
Serendebyte
Sai Krishna YATHVIK SAI TRINADH PAPINENI
Accenture
Ho Mahesh,
Could you please help me to understand the purpose of the clipboardProperty pyStateListcase in your java code.
when I open the function in designer studio I found 3 input parameter listPage, keyProp and className.
Thanks in advance.
JPMorgan Chase & Company
Bits in Glass
Hi Raj
You can use OOTB function
@Utilities.pyRemoveDuplicatesFromPagelist(ListPage,PageListName,DuplicateCheckProperties) and pass the required mandatory parameters to remove duplicate items in the list.
Ex: Configure like as this @Utilities.pyRemoveDuplicatesFromPagelist(Primary,".DetailsList","Name")
Here Primary is clipboard Listpage name, DetailsList is my pagelist and Name is the comparing pagelist property to check duplicates with same name value in the list.
Hemalatha
Anupriyadarshinii Rajasekaran Hemalatha Sura Korikana Sriraj Yesuraju Chokka Zakir Hussain Khaleel
Thanks All!
Most of them worked.
Glad to hear that most of them worked! Would love for you to share your resolution for this and then if you could mark your reply as Correct Answer, that would be great! I have marked your post as Assumed Answered based on your last reply.
Thanks!
Optum
Hi Raj
Hemalatha.
This one has worked for me
Korikana Sriraj Aditya Tripathi Shubham Grover Maleesha Wilfred
