![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689981000/df9ce743-f881-4813-b0e9-081beaab3cbd.jpg?itok=IztzJ5Dt)
Areteans
Step by step process of Creating a ValueGroup and PageGroup properties please
Please help me with a step by step procedure in creating property of type PageGroup and ValueGroup.
Areteans
Here are the steps I followed.
Created a property rule called Phone. Changed its mode to Value group.
Created a section rule. Dragged the property twice into it. Opened the cell properties. Changed the property manually to .Phone(Home). and .Phone(Office).
Used a review form to refer it. Here is the screen shot that reflect values in clipboard.
Virtusa Consulting UK
HI, Both ValueGroup and Page Group are modes of properties. So, the step by step process to create either of them would be to create a new property and select the appropriate mode for the property.
Areteans
Created such property. (Phone as Value Group). After that not able to proceed.
I want to assign key to the property and a value to it.
Help me in attaching some groups to it, like Phone(home), Phone(office), post which I want to access that in a Section rule to get the data during run time. After that I would like to display those in report.
A similar one I want it for Page Group.
Hi, You can set the value in the value group in the property set method. And the same can be referred in the section as well for display purpose.
Areteans
Thank you for responding.
I did not use any activity for this. But solved it. Thank you for your time.
Areteans
VISPL
when i create a page group property it asks for page defination what should be passed in it??
Areteans
Any page or page list property is nothing but a complex type property. Hence give a class name as its definition. As if you are creating a object of a class.
