Capgemini
BR
Last activity: 16 Aug 2017 20:18 EDT
How test multiples Connect Soap in PEGA.
I would like understand, if it is possible using one activity in Pega that can test a connectivity for all connect SOAP that I have available in my enviroment.
I have been checking, the activity ValidateInfrastructure, available in Rule-Connect-SOAP class, that are using to teste for each connector SOAP, when we are clicking in button "Test Connectivity".
My question is: Is possible reuse this activity (ValidateInfrastructure) to test multuples connect soap in the same time or parallel and get the result , where after this processing, you can generate one report ?
Thank´s!
Guilherme Valiño
***Edited by Moderator, Maryrita: moved to product Support from Lead System Architect***
