Interrogation issue in SAP cell.
I am not able to interrogate a field as mentioned in the screenshot.
I have to copy that and paste into somewhere else.
Plaese help me in that.
When you use the bulls-eye what does it interrogate?
Have you tried looking for the control in the Virtual Controls tab?
I have tried everything as mentioned above.
So Please provide me another alternative.
"I have tried everything as mentioned above."
You have not mentioned doing anything...
Please go to the object explorer in Studio and highlight the control you've tried to interrogate.. what is being outlined - can you show me a screenshot?
Now go try finding the control in the Virtual Controls Tab while in Interrogation Mode. Right click the controls to highlight and create them if necessary. Do you see anything further down in the hierarchy? Can you attach a screenshot once you've found the control in the Virtual Controls Tab?
The only interrogation is performed is that table filed
but I want the last cell value
this is my requirement
Please help me in that
Am sharing the screen shot of that table
Does the table interrogate as a Grid control? Are you able to provide any of the screenshots that I mentioned in my original response? You attached the same image that is in your original post.
It is interrogating the whole table.
But I want the last element of the cell.
for the verification to some other values.
please suggest me the better idea like how to do that.
No it is not interrogating the required thing.
Have seen the virtual controls as well but am not able to do that.
I suggest that you open an SR with support as it appears you need someone who can look at your machine. I believe you will need to add some controls for SAP from the Virtual Controls tab however, so that is the likely solution.
If you do open an SR, please post the SR number here for tracking purposes.
The following article will be help you in creating an SR-
My Support Portal explained for Pega Robotic Automation (formerly OpenSpan)
