ANZ Banking Group Ltd
Last activity: 4 Oct 2018 6:08 EDT
Unable to populate the results after calling Data Page from Control rule
Hi Team -
I have a requirement to populate the Datapage results in a property through Control rule.
Results are not populating when i call the Data Page from Control rule, which has been referred in a property.
Followed the below steps, But not populate the results:
1. Created a section and a property
2. Created a Control rule, is referred in the created Property
3. Control is calling Datapage by passing parameter to get the relevant results.
Note: I knew that Datapage results will be populated directly from property level itself instead Control rule. But it's required for KYC Type property where I don't use the section.
