  CGI
Disable already selected value from drop down list
Use case: Disable already selected value from drop down list
Query 1: How to disable already selected value from Autocomplete and DynamicSelect/ dropdown control.
Query 2: If not possible in Autocomplete and DynamicSelect/ dropdown control, then what is the option.
We need similar behaviour in below screen shot taken from PDN.
Thanks in Advance.
I believe there is no OOTB way to achieve this with Auto-complete or Dropdown control. This will need some customization.
@Vidyaranjan Could you pull someone from PDN development team to help out here on this control.
Hello Rajasekhar,
Thanks for posting queries in PDN.
As per Rawap's reply you may need to customize to achieve this requirement.
I hope the below article will help you in customization using javascript and jQuery.
Thanks & Regards,
Durga
  CGI
Thanks Durga.
We have gone through url shared.
Could you please share the steps to custization in Pega?
Thanks in Advance!
  CGI
Thanks Durga.
Thanks in Advance!
  CGI
Thanks Durga.
Thanks in Advance!
  Leela Pothineni Sandeep Khare
  CGI
Thanks Durga.
Thanks in Advance!
  CGI
Thanks Durga.
Thanks in Advance!
Hello Rajasekhar,
Sorry for delay in response since I am quit busy .
I will try to create the scenario with your requirement and will update you soon .
Meanwhile , you can also try by using developer tools inspecting the dropdown element and get the class/ id and implement the below jquery script in Auto - generated section or userworkform
$(document).ready(function() {
$(".preferenceSelect").change(function() {
// Get the selected value
var selected = $("option:selected", $(this)).val();
// Get the ID of this element
var thisID = $(this).prop("id");
// Reset so all values are showing:
$(".preferenceSelect option").each(function() {
$(this).prop("disabled", false);
$(".preferenceSelect").each(function() {
if ($(this).prop("id") != thisID) {
$("option[value='" + selected + "']", $(this)).prop("disabled", true);
Thanks & Regards,
Durga
Hi Rajasekhar,
Adding point to above reply.
The code provided is just a sample.
Once you got the class/id of the dropdown element then replace the ".preferenceSelect" with your class/id.
Thanks & Regards,
Durga
  CGI
Hi Durga,
We tried and it is not working. could please guide by details.
As you mentioned, we identified the dropdown id
In userworkform added below code
<script>
$(".NewWorkCaseType").change(function() {
Hi Durga,
<script>
</script>
Hello Rajasekhar,
Sorry for delay in response .
Please try with below code snippet and let me know the outcome.
$("#NewWorkCaseType").change(function() {
$("#NewWorkCaseType option").each(function() {
Hello Rajasekhar,
$("#NewWorkCaseType").each(function() {
Thanks & Regards,
Durga
  CGI
Thanks Durga,
Included above code in "Userworkform", within script tag and it is not working.
Thanks & Regards
U Rajasekhar
  CGI
Thanks Durga,
Thanks & Regards
U Rajasekhar
  CGI
Thanks Durga,
Thanks & Regards
U Rajasekhar
  CGI
Thanks Durga,
Thanks & Regards
U Rajasekhar
  CGI
Thanks Durga,
Thanks & Regards
U Rajasekhar
Hello Rajasekhar,
Can you place the alerts(thisID)/console.log(thisID) and check whether it is displaying the 'id' of the selected option properly or not. You can confirm this by inspecting the select option element.
Actually this needs debugging the code to check where exactly its failing.
Thanks & Regards,
Durga
  CGI
Could you please let me know, where to place the alerts(thisID) in below code
Thanks in Advance..........
Hello Raj,
Alternatively, how about using multi-select control. With this control, on selecting a value(say Abigail starting with ab letters), it is not listed again(equivalent to getting disabled) in the list. Refer the below screen shot:
PS: Screen shot taken from Pega 7.3.1.
Rincy
  John Summerlin
  CGI
Thanks.
We are using 7.2, MultiSelect is not there.
  CGI
  CGI
Can someone reply to queries........
  Ncs Pte Ltd
SG
I think you can create similar functionality by using auto complete and repeating dynamic layout.
1. Create two Page list. One for your source and one for selected items. Add auto complete control with source pagelist.
2.Above autocomplete add one repeating dynamic layout with selected item pagelist, in repeating dynamic layout add a section and in that section use a formatted text/text input with selected items pagelist property name.
3.Now on selection of item from autocomplete. Run a data transform or activity to copy selected item from source pagelist to selected item pagelist and delete item from source pagelist.
4.Same thing you can use to delete item from repeating dynamic layout add back item to source pagelist i.e autocomplete
  CGI
Thanks for your response.
Requirement is to display complete list and selected under same drop down i.e. as mentioned part of post.
Can someone guide...........
Hi @RajasekharU0829,
After reviewing this with our SMEs in GCS, we have decided your best bet would be to get in touch with our Consultint Team to help you with this. Please contact your Account Executive to get that set up.
Thanks!
  CGI
Thanks.......
