I have read the handbook for Pega PRPC 6.3, How can I create subflows within the main flow? Is there any resource/tutorial that shows a step by step approach?
Also I need to add steps and parameters for a flow, how shall I do that?
The below help article has more information about adding a subflow (also known as a subprocess) to a flow in Pega 6.3:
https://community.pega.com/sites/default/files/help_v63sp1/Default.htm
The more general help for flow rules has some information related to configuring them for adding in steps and parameters:
You might also want to take a look at the Case Designer help, which can be used as an alternative to, and along with flow rules, to create work processes:
Hope this helps!
-Kurt
