how to read csv files from external path without using file listener
Why it is required not to use File Listener. File listener is the best way to achieve this. But just in case, you have a license issue or something, first I need to know what would be the action after the import. At this moment I assume that, you will just be populating the data to persist in Pega. If that is the case, you may use the activity (or customize it by saving it in your application with a different name) pxUploadCSVResults. This activity is used once you try to populate the rows of a Data Type by importing a CSV file. I think your functionality might be achieved in the same way.
I have a requirement where I need to read data from a CSV file with two columns which is placed in the server (C://xxx) and then save the data of one of the column from the CSV to a DB table. I have tried using MSOParseExcelFile, it gives error saying the " the template and file doesn't match". pxUploadCSVResult doesn't have parameter to pass the location. Can anybody suggest any approach to achieve this requirement.
Hello!
Thank you for posting your query on PSC. This looks like an inactive post and hence, we suggest you create a new post for your query. Click on the Write a Post button that’s available on the top right pane of this page. Once created, please reply back here with the URL of the new post.
We have also sent you a private message opening up a communication channel in case you have any further questions.
Thanks!
I have a requirement where I need to read data from a CSV file with 44 columns which is placed in the server path like: bea/track2500/pega/hr and i need to save the data into our external table with out using file listener ,because i need to read the data every weekly ones.
Hello!
Thanks!
