Aaseya
Last activity: 31 May 2017 20:13 EDT
While add new entry to decision tables should avoid duplicate entry check to avoid adding same entries
1) While adding new entry or new association to decision tables there should be duplicate entry check to avoid adding same entries.
2)The labels of the fields and values which constitute the rule definitions and decision tables should not be displayed in codes/numbers. Labels should be displayed as text .
3) In decision tables in the Admin Portal, Admin user should not be able to enter a value that is not defined in the system at that moment.(Ex:System will warn admin user that she/he must enter a currently existing value for required skill field.)
***Moderator Edit: Vidyaranjan | Updated Categories; tagged SR Exists***
