Reports not updating while switching application
We are facing an issue with the reports listed on the reports tab in the portal. If a users logs into an application and clicks on the report tab, the reports available for that application are getting listed correctly. Now if the user, switches application and clicks on the report tab of that application portal, the report list of earlier application only gets displayed there. The report list is populated using the datapage D_pzRBCategories. This datapage does not seems to be flushed while switching application so the same old list reflects everywhere, until the user logout and login again. Is there any solution to fix this?
***Moderator Edit: Vidyaranjan | Updated SR details***
Hello!
On reviewing the SR, we see that the issue is resolved. The cause of the issues was found that the source for the report list was "D_pzRBShorcuts" which was requestor scoped. Switching apps changes the thread, but not the requestor scope.
The resolution was to change the data page "D_pzRBShorcuts" from requestor scoped to thread scoped. Then, every time an application switch is done, the data is flushed and is loaded again. Apply HFix-35595 to fix the issue in Pega 7.1.5. However, the same issue is fixed in the later releases from Pega 7.2.
Thank you,
Hello Venkatesh,
May I know the PRPC version at your end?
We already have one hotfix for PRPC 7.1.8 -HFix-26997. If your on same version can request for the same.
Shanthini Charles
Hi Shanthini,
We are using PRPC 7.1.5 version. Is there a HotFix for this version?
Venkat
Hi Venkatesh,
Can you please do a private edit of D_pzRBCategories data page, change its scope to 'Thread' and check if the issue is fixed?
Thank you,
Madhuri
Hi Madhuri,
That is a final rule. If we have to customize that, then we have to rename it. That will again be a problem.
Venkat
Hi Venkatesh,
It is just to do a quick check at your end. The issue is fixed in later releases. It is recommended that you upgrade to the latest version. However, if you require a fix in 7.1.5 specifically to meet your business requirement and it is not possible to upgrade, you may please raise an SR with all the details.
Thank you
Hi Venkat,
Please let us know if you do log an SR for this and its ID. That way we can track it and follow-up this discussion with the resolution.
Thank you,
Hi Lochan,
I have raised SR-B52906 for this issue.
Venkat
Hi Venkatesh,
Thank you for sharing the SR details. I have tagged it along with the issue description for tracking.
Thanks!
Hello!
Thank you,
