    UnitedHealthcare
Do Lock controls need to be global?
We're having trouble with a datatable becoming corrupt. I believe it's caused by multiple asynchronous processes updating the table. I recently discovered the Lock component and believe this could solve the problem. However, the documentation doesn't specify if the lock should be a local or global variable. Does it matter if the lock is local or global?
