Societe Generale
Last activity: 9 May 2017 11:16 EDT
Agents parallel processing
Hi Team, We have a requirement to enable one standard agent on multiple nodes to achieve parallel run and improve performance for case creation and also we have a requirement to make the process sequential if updates are for same case, that needs to be processed sequential in the order we received. Currently we are running agent in only one node which is causing the delay in case creation. Any suggestions to handle this without much of customization to the existing code.
