Infosys Limited
Issue with harness in CPM upgrade
Hi all,
we are unable to create an Interaction case after our upgrade. We are facing issue in launching the harness in CPM framework,
we could found out that the issue is due to function not getting compiled propery, Does any one has faced similar issue can help us .
Error(s) detected while generating java. Compiler reported: ---------- 1. ERROR in //opt/WAS/profiles/AppSrv01/temp/AppSrv01/wasap01/wasap01_PRPC/prweb.war/com/pegarules/generated/ProcessXSLT_071027_M_J_Gnia4_2wyx2U_GHKbA.java (at line 117) tFactory.setAttribute(javax.xml.XMLConstants.ACCESS_EXTERNAL_DTD, ""); ^^^^^^^^^^^^^^^^^^^ ACCESS_EXTERNAL_DTD cannot be resolved or is not a field ---------- 2. ERROR in //opt/WAS/profiles/AppSrv01/temp/AppSrv01/wasap01/wasap01_PRPC/prweb.war/com/pegarules/generated/ProcessXSLT_071027_M_J_Gnia4_2wyx2U_GHKbA.java (at line 118) tFactory.setAttribute(javax.xml.XMLConstants.ACCESS_EXTERNAL_STYLESHEET, ""); ^^^^^^^^^^^^^^^^^^^^^^^^^^ ACCESS_EXTERNAL_STYLESHEET cannot be resolved or is not a field ---------- 2 problems (2 errors) Compile failed.
