    AMERICAN EXPRESS
Last activity: 11 Apr 2017 19:59 EDT
REST Connector Connection pool settings inside pega or application server
The application has REST connectors to publish message on solace queue using POST method. The solace has configuration to set max connection size. Once reached max size, solace is not accepting more connections.
Could we configure max connection limit in side pega application. At run time, before publishing message, Pega should be able to verify how many connections already opened before publishing message on solace queue. It would be able to publish later by queue items.
Please respond what options we have to configure the max connection limit either on pega or application server hosted the pega applications.
***Moderator Edit: Vidyaranjan | Tagged SRExists***
