Captcha Image Reading
I want to read the captcha image using RPA on a website. Kindly let me know if it possible where i can capture captcha image in RPA.
Unfortunately, Captcha images are designed specifically to prevent you from doing RPA processes. Often the terms of service for using web sites like this also restrict you from doing any automation. So, basically if you run into a Captcha you will need to make this a manual step.
