Alfabank
RU
Last activity: 4 Apr 2017 10:33 EDT
Data pages with parameters in Offline mode
Hello!
We currently have a problem with using data pages with parameters in offline mode on mobile device. From Pega guys we know that this is supported and custom populator function is needed for that. Unfortunately, we could not get more details from the guys so far. Could someone please explain, how all this is woking on mobile device and how to write this populator function?
This is about regular data pages, not about large ones.
Alexey
***Updated by moderator: Lochan to add Categories; add SR details***
Likes (2)
THEERDHA CHANDANA SAJJA Mukhee Jyothsna -
Hi Alexey
I know you have mentioned in your post that you are not using large data pages. But, have you taken a look at this post and seen if this would still be applicable for regular data pages as well?
https://docs-previous.pega.com/custom-populator-javascript-functions-large-data-pages
I have personally not tried or tested, just did a quick search and thought I'd point you to it if you haven't already seen it.
Alfabank
RU
Hello!
It seams, that you are right. Will wait for answer from support just in case.
Thank you!
Alexey
Hi Alexey,
I read that you are waiting for a response from support. Does this by any chance mean that you have an SR open with Pega Support for this query? If so, could you please share the SR# here?
Thank you!
Alfabank
RU
Hi!
Yes, SR-B41097.
Thanks.
Thanks Alexey,
I have updated your original post above to reflect that information and also left a pulse post on the internal app for SRs since I wanted to conect the two for the engineer handling the SR. This linking usually helps!
Alfabank
RU
Hello!
yes, I've read it. The idea is clean, but large data pages have a bit different nature and different type of storage, so, this information is not directly applicable to regular pages.
It seems that this should look something like in this article - https://docs-previous.pega.com/cascading-drop-down-controls-offline-pega-7-platform-applications
