Tata consultancy services(TCS)
need Changes needs to be done to Runtime Config file to make it invoke AgileDesktop.EXE
Openspan version : 7.1.90 .. I have developed Agile desktop solution and tested it in studio Agile UI,Window form, Everything worked perfectly and locally deployed which inturn created Proj.Openspan and Proj.Manifest files.
Now I have launched Openspan Runtime.exe and try to load local project and located Proj.Openspan file. Project got Loaded successfully
But issue is I cannot see the Agile Desktop UI, in simple Agile desktop application is not running.
I have read all the Agile implementation guide and everything but cant find the catch here.
Let me know what knid of settings i need to do it Runtime Config file so that when i launch my package using Runtime.exe agile desktop runs.
or let me know other wise
To run Agile Desktop you need to launch OpenSpan.AgileDesktop.exe. You must either have OpenSpan Management Console configured, or set the StartupProject key in the RuntimeConfig.xml. It is best to select Agile Desktop from the Runtime installation.
