AdeptView
AdeptView
AdeptView
Posted: Mar 13, 2017
Last activity: Mar 13, 2017
Last activity: 13 Mar 2017 11:01 EDT
I would like to know the way to generate report on rules, its highest version and availability of the highest version
Rakhesh
You can use the Rule resolution feature in report definitions. Write a report definition on Data-Rule-Summary class and enable rule resolution to achieve the requirement that you are looking for.
You can look at pxRuleWarningsInChart RD for reference.
Let us know if this helps :)
Hi Rakesh,
You can use pxHighestRuleVersionsInApp report definition, you can try to add the availability param into this report for your full requirement.
Hope this might help you.
Regards
Mahesh
